- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighhawk CAX80 Mystery Wireless IP Address
- Mark as New
- Bookmark
- Subscribe
- Permalink
Posted this in the Nighhawk Wifi 6 forum. Recommeded I try here.
Under Attached Devices I show a device using IP address 192.168.1.235. It's identified as a phone and connection type is 2.4G Wireless.
If 2.4g disabled device goes away. 2.4g back on it reappears. Power level does not appear to affect it.
I have physically identified all wired and wireless devices but can't determine what this device is.
In the Admin Logs, it logs an event every ten minutes or so. The count has been a high as 74 in one event. Any idea what this could be or how to locate it? Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighhawk CAX80 Mystery Wireless IP Address
Change the PW on the 2.4Ghz radio and see if that device connects or not or someone complains. You'll need to update wifi devices for this radio with new PW.
- Mark as New
- Bookmark
- Subscribe
- Permalink
"Change the PW on the 2.4Ghz radio and see if that device connects or not or someone complains. You'll need to update wifi devices for this radio with new PW."
Can you explain what you mean by PW? Password?
The thought is to cahnge the WiFi password and see if it still connects? If not I would need to update the password for all the connected devices to the new router password, correct?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Under Advanced/Admin Attached Devices I selected "Block" on that device. It still shows activity. Is changing the password the only way to completely remove the device from accessing the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
A bit more info.
Under Admin/Logs/ Include in Log, there are eleven possible event categories to log. Only one that appears to cause events is: Gateway Operation (startup, get time, etc). Receive a log event every several minutes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has changing the password helped on this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for asking. Turned out not to be a password issue.
I did a web search on the offending device's Mac address. Belongs to a China company. Not surprising but concerning. Did a search on the company's name. Was associated with Shark vacuum robots, which I have one. Being on the floor and under a bench, I completely overlooked it.
Looked in the app and sure enough, the mac address matched the mystery device. Turned Off the vacuum and issue went away.
I did change the WiFi login password so I'll need to log in to the Vac app with the new password.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah good. Glad you figured it out.
Enjoy.
