× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
Reply
NightHawk CAX30 is rejecting connection
DavidNomo
Hello,
My NightHawk CAX30 is rejecting wireless connection after password update.
When i try to connect it shows "The Wi-Fi network "NETGEARXX" requires a WPA2 password"
I have not changes anything on my Mac, before it was able to connect to same Wi-Fi without any issue.
Checked Advanced => Administration => Logs, it shows WLan access rejected: incorrect secuirty from Mac address......
can you tell me what is going on?
Message 1 of 4
Guru
Re: NightHawk CAX30 is rejecting connection
What device are you connecting with?
Did you use the forget this network feature then try to re-connect then re-enter the password?
Revert the PW change on the CAX to what had been working if nothing else to see if this resolves.
Any special characters in the password configuration?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
DavidNomo
What device are you connecting with?   FROM MacBook
Did you use the forget this network feature then try to re-connect then re-enter the password? I did it, also refreshed DHCP too
Revert the PW change on the CAX to what had been working if nothing else to see if this resolves. Yep changed back, also rebooted CAX
Any special characters in the password configuration? Yes, but it was working before the issue
Message 3 of 4
Guru
Please try something simple with out any special characters and see.
Is this the only device that is having problems or do all devices see this?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 169 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
