Orbi WiFi 7 RBE973
Reply
NightHawk
JackTheLad
Follower
NightHawk
OK, I'm a bit of a novice here.  Just purchaesd the Nighthawk AC3200 to replace my BT Smart Hub 6 which is poor to say the least.  I find out now that my phone line will not plug in and I need a seperate modem.  What do you recomend?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
Guru
Re: NightHawk
Please review the CM1150v which support phone line connections:
https://www.netgear.com/support/product/CM1150V.aspx
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 3
antinode
Guru
Re: NightHawk
> [...] replace my BT Smart Hub 6 which is poor to say the least. [...]
   "poor" in what sense?  Why replace it?  If it can be configured in a
modem-only mode, then you ought to be able to use the R8000 as your
router with it.
> [...] I need a seperate modem. [...]
   If you insist on buying a modem, then Netgear DSL modems have "DM"
model numbers, "DM200", for example.  Non-Netgear DSL modems may also
exist.
> [...] BT Smart Hub 6 [...] my phone line [...]
> Please review the CM1150v which support phone line connections: [...]
   Not a very useful suggestion for a user with DSL service.  (Perhaps
even more useless than your usual "My Setup" noise.)
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 378 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
