- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AC1900 C7000V2 Modem Router slow download speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 600 MBPS coming into the unit and if I get within 3' of it, I can get about 211 coming out via WIFI. That is with the Ookla speed testing. Unplugging it for a period doesn't change anything. Firmware is up to date. What can I do to improve this? Is the modem router unit bad, shot, junk? Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AC1900 C7000V2 Modem Router slow download speeds
1. what wired speed to you get?
2. are you testing over 2.4ghz or 5ghz?
3. what actual device are you testing the speeds on?
4. You won't hit 600mbps over wireless on that router. 300-400mbps is more around the range you can expect over 5ghz for that devices.
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@RND1023 wrote:I have 600 MBPS coming into the unit and if I get within 3' of it, I can get about 211 coming out via WIFI. That is with the Ookla speed testing. Unplugging it for a period doesn't change anything. Firmware is up to date. What can I do to improve this? Is the modem router unit bad, shot, junk? Thanks.
It is premature to declare your modem/router unit as bad, shot, or junk.
Testing internet throughput over a Wi-Fi connection is primarily a reflection of the device you are running the test on.
Ookla native application test is appropriate for your connection if your are using a computer connected to the modem/router through a good Ethernet cable. If your results indicate you are obtaining the throughput that compares favorably to what you are purchasing from your ISP, then you can focus on configuration of your Wi-Fi.
My setup: Comcast -> Netgear CM2050V -> Netgear R9000 (Voxel V1.0.4.68HF)
- Mark as New
- Bookmark
- Subscribe
- Permalink
According to this post it appears to be a regular problem with this modem router unit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@RND1023 wrote:According to this post it appears to be a regular problem with this modem router unit.
c7000v2 Slow wifi speed - NETGEAR Communities
There are a lot of variables involved with the throughput capacity of a Wi-Fi connection. Placing blame on the modem/Wi-Fi router hardware would be relatively low on the list. At the top of the list would be the configuration of the Wi-Fi router, capacity of the device you are using to test, and the radio frequency environment where you are testing. The environment includes home construction material and interference from other Wi-Fi sources,
- Mark as New
- Bookmark
- Subscribe
- Permalink
"But Wifi is only around 270 Mbps." This is pretty good and around the top range that you seen on 5Ghz AC wifi. Most devices top out at around 300-500Mpbs. You'll not see anywhere near 900Mpbs on 5Ghz WiFi on this model modem.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
My ethernet speed with a new cable & Ookla testing is about 94 with 2.4. I'm using my laptop.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My ethernet speed with a new cable is about 94 with 2.4.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@RND1023 wrote:My ethernet speed with a new cable & Ookla testing is about 94 with 2.4. I'm using my laptop.
Your statement above does not make a whole lot of sense. New Ethernet cable connecting what to what?
Over the 2.4 GHz Wi-Fi band, a test throughput of 94 Mbps is not bad. How old is your laptop? What operating system?
Have you run a throughput test using your laptop connected to the 5 GHz band?
- Mark as New
- Bookmark
- Subscribe
- Permalink
All right. Connecting the modem router to the pc via an ethernet cable connection then running the Ookla speed test on the 3- or 4-year-old HP updated windows 10 pc model #15-au063nr. Can't run 5GHz with ethernet. Have previously posted 5GHz Wi-Fi speed. Within 3' of the modem router I got a 211, within 6' of the modem router I got 198 with the Ookla speed test. The Exfinity speed test isn't worth the effort to run.
I previously said I had 600 coming in, I am wrong there, it is 400. How can 94 going out be "not bad", when you have 400 going in? That doesn't make sense either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@RND1023 wrote:All right. Connecting the modem router to the pc via an ethernet cable connection then running the Ookla speed test on the 3- or 4-year-old HP updated windows 10 pc model #15-au063nr. Can't run 5GHz with ethernet. Have previously posted 5GHz Wi-Fi speed. Within 3' of the modem router I got a 211, within 6' of the modem router I got 198 with the Ookla speed test. The Exfinity speed test isn't worth the effort to run.
The throughput coming in is over the cable. I agree the Xfinity test is not worthwhile. Stick with Ookla.
What you have coming in over cable is what you should have going out over Ethernet to a computer. You will not see that over Wi-Fi. If you have Wi-Fi in at the computer at 100 Mbps over the 2.4 GHz band that is good. If you have Wi-Fi in at the computer at 300 Mbps over the 5 GHz band, that is good.
Recommended reading to help you understand Wi-Fi. https://www.duckware.com/tech/wifi-in-the-us.html
Does your laptop have an Ethernet input port or is it Wi-Fi only?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Check your hardwired pc/laptop to see if its actually connecting at gigabit speeds. When you hit 94mbps it usually means you're only connecting at 10/100mbps speeds and not gigabit. And you're hitting faster over 5ghz so the modem is supplying more speed.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is a screen shot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the article it's amazing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You must not have had your laptop/pc hardwired in at that time as there isn't anything connected to the lan ports.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That is the way I use it. Would you like me to plug in the ethernet to test it for that info?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Because we want to see if you're actually getting the speeds you pay for. You won't max them out wireless but wired you should be able to. Its pointless to troubleshoot why your wireless is only getting 200mbps if you're modem is only outputting 200mbps because of a poor connection or bad provisioning.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I guess that means you would like to see those specs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I plugged the ethernet in and ran three test for the heck of it and my best was 98.
Here is an ethernet screen shot. Looks to me like it is running 100.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I want to thank you both for your patience and help checking things out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@RND1023 wrote:I want to thank you both for your patience and help checking things out.
You are making progress in understanding your situation. That is good!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since I don't use ethernet, does that really matter? I found this attachment for my WIFI. It shows a speed of 780 which is pretty darn good, but I don't get why it doesn't show up in the speed test if that is correct.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is all, definitely, very technological. Hats off to whoever came up with all this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That'd be your link speed. That's not actual throughput. throughput tends to be around 55-65% of link speed.
But we first need to figure out if you're actually getting the full speed from the modem. That's why we ask the hardwired question. If your hardwired speed from the router/modem is only 200mpbs, your wifi isn't going to be any faster than that as the bottleneck is what the modem is supplying.
Again, its pointless to troubleshoot wifi until we determine if you're actually getting the speeds you pay for.
