ljmagyar's avatar
Dec 09, 2021
Nighthawk CAX30 AX2700 Drops network connection randomly
The actual model number of my router isn't shown in the drop down and it wont let me enter it manually.  I have a Nighhawk AX6 CAX30 AC2700 router.  I bought it new on October 13 2021 to save $15/month xfinity modem rental extorsion.
I have been dropping connection to the WAN and having what appears to be a complete POR of the modem each time it happens.  It is a momentary drop - after the reboot of the router happens, WAN returns like nothing ever happened.
  • I have had xfinity come out several times to check and they say everything is fine.
  • They have replaced my Nighthawk with one of their own XFI routers and I have not dropped (that I have been able to catch).
  • I am not sure if they (xfinity) are doing something with the signal to disrupt personally-owned routers to force a rental or not - conspiracy theorists would say yes.
I have seen several other similar posts with no direct answer other than 'try updating the firmware'.  These are older (at least 6 months) and no new movement.  My router is not currently powered on or connected to the WAN, so I can offer no further information at this time as far as network diagnostics.
ANY hints, direct fixes, known solutions, or recommendations to return it and get a D-Link would be appreciated.
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
    Please post a copy and paste of the modems connection status page.
    Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    Be sure to power OFF the modem for 1 minute then back ON.
    https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
    https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
    https://highspeed.tips/docsis-events/
    Thank you.
  • I just installed your same NETGEAR modem/router three days ago (CAX30 AX2700 AX6). Yesterday and today I've had wifi drops, same as you. Ethernet connected devices work well, wifi devices connect to the router but the signal is not passed out from the router. The 2.4 and 5 bling but devices 'cannot connect'. The only way to remedy this is by restting or power cycling the modem/router.
    Have you gotten a solution?
    • ljmagyar's avatar
      ljmagyar
      Star
      No.  Netgear tech support only suggested "reset the device".  If it happens again they will issue an RMA.
      • FURRYe38's avatar
        Please give feedback to the other questions presented.
  • I experienced even worse than the this community member.
    I purchased CAX 30 AX2700 on Nov. 18, replace the item on Dec 3 as per the suggestions of Netgear engineer, still the problem is persisting, the Netgear engineer suggested to get the product from different retailer, or they would provide tested modem directly from them. Because the whole batch from the retailer might have hardware issue. The tech called me once after 12hrs instead of 2hrs., as per his assurance. I was at work that time, but I could not reach him back, despite I sent email back to him. I called, again tech-support, another tech support guy said he had to investigate and would call me back in few hours, but next day he called me to sell the extended warranty but not to resolve current issue. When I called back again, another technician asked me to go all over for the trouble shooting and assured to call back yesterday evening (01/03/2022) at 6pm PT, but never called me. I sent emails but have not got reply. This way, I suffered physically, emotionally, and financially (because work loss and cellular data usage) for over a month, but still have not heard any concrete resolution from them.
    Things to be noted, this product has known problem but Netgear does not want to admit rather acting as escape-goat pointing out problems to internet provider. Very poor customer service and technical support, hard to reach the technicians lack up follow up as assured, harder to reach the technicians. Rather than helping and addressing the customers issues they trying to sell their services (extended warranty).
    • FURRYe38's avatar
      You may want to return the modem to place of purchase then.
  • Is there some kind of FIX to this that actually works?
    Every single day I have to re-boot the blasted thing - and then it may or may not work! I only have my cell phone and Amazon FireTV connected, so it cannot possibly be muddled up because it's got too many devices since it supposedly is "Designed to Handle 35+ Devices at Once"
    I just want to check my email or the news headlines, make the odd Amazon shopping search on my cellphone and/or watch a simple streamed movie from my service. Is that too much traffic?? I end up having to use my mobile data most of the time and that is adding up like crazy.
    I purchased this CAX30 AX2700 - Wi-Fi 6 Router and Cable Modem All In One - from Costco on October 5, 2021
    I'm having to type this question with my computer at work. Frustrating.
    I would NEVER recommend this modem router to anyone. ESPECIALLY at a $250 wallop!
    • ljmagyar's avatar
      ljmagyar
      Star
      AnnoyedCAX30Uzr said"
      "I purchased this CAX30 AX2700 - Wi-Fi 6 Router and Cable Modem All In One - from Costco on October 5, 2021"
      Hmm... I got mine from a Costco on Oct 13, 2021... is this a special model made for COSTCO?
      Yesterday, Xfinity came out again and re-checked everything. All the signals were good at the tap and good at the house.  they were measuring 5 to 6 dBmV on all channels - which is an improvement from the 4 to 5 it was before I complained about a weak signal for the 4th time.
      The tech then came in the house and we ran further diagnostics, not finding an issue with the signal strength.
      He called the tech help desk and then asked them to provision the modem... something I had not heard (doesnt mean it didn't happen) them do before.
      I work from home - for the next 2 hours I continually dropped connection.  All at once, I got a text from Xfinity -
      266278:XFINITY UPDATE
      Our processes have completed for your Xfinity services. Please reply Y to confirm that your service is restored and issues have subsided or N to connect with an agent. Txt Help or Stop. Msg&DataRatesMayApply
       11:25 AM
      From the time if that text, I had not had a disconnect.  Sometime near 3PM I got a call from Xfinity asking me if everything was ok.  I told them I was reserving judgement.
      Up to the tech's visit yesterday, the disconnects had been increasing in frequency to the point of being impossible to stream TV or stay connected to my VPN for work.  From the data, it appears that Xfinity boosted the signal strength from before and did the PROPER provisioning this time.
      Here's what the connection looks like this morning.
      <tabindex=-1>Startup Procedure</tabindex=-1>
      ProcedureStatusComment
      Acquire Downstream Channel507000000 HzLocked
      Connectivity StateOKRegistration Complete
      Boot StateOKOperational
      SecurityEnabledBPI+
      IP Provisioning ModeHonor MDDIPv6 only
      <tabindex=-1>Downstream Bonded Channels</tabindex=-1>
      ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectabables
      1Locked256 QAM5507000000 Hz6.5 dBmV42.8 dB00
      2Locked256 QAM1477000000 Hz6.2 dBmV42.5 dB00
      3Locked256 QAM2483000000 Hz6.1 dBmV42.6 dB00
      4Locked256 QAM3489000000 Hz6.3 dBmV42.8 dB00
      5Locked256 QAM4495000000 Hz6.1 dBmV42.5 dB00
      6Locked256 QAM6513000000 Hz6.1 dBmV42.6 dB00
      7Locked256 QAM7519000000 Hz6.0 dBmV42.4 dB00
      8Locked256 QAM8525000000 Hz6.2 dBmV42.5 dB00
      9Locked256 QAM9531000000 Hz6.4 dBmV42.6 dB00
      10Locked256 QAM10537000000 Hz6.5 dBmV42.6 dB00
      11Locked256 QAM11543000000 Hz6.3 dBmV42.5 dB00
      12Locked256 QAM12549000000 Hz5.9 dBmV42.5 dB00
      13Locked256 QAM13555000000 Hz5.9 dBmV42.4 dB00
      14Locked256 QAM14561000000 Hz6.1 dBmV42.4 dB00
      15Locked256 QAM15567000000 Hz6.3 dBmV42.4 dB00
      16Locked256 QAM16573000000 Hz6.2 dBmV42.4 dB00
      17Locked256 QAM17579000000 Hz6.2 dBmV42.4 dB00
      18Locked256 QAM18585000000 Hz6.2 dBmV42.4 dB00
      19Locked256 QAM19591000000 Hz6.2 dBmV42.4 dB00
      20Locked256 QAM33453000000 Hz6.2 dBmV42.8 dB00
      21Locked256 QAM34459000000 Hz6.2 dBmV42.8 dB00
      22Locked256 QAM35465000000 Hz6.3 dBmV42.8 dB00
      23Locked256 QAM36471000000 Hz6.1 dBmV42.7 dB00
      24Locked256 QAM38429000000 Hz6.5 dBmV43.0 dB00
      25Locked256 QAM39435000000 Hz6.5 dBmV42.9 dB00
      26Locked256 QAM40441000000 Hz6.1 dBmV42.8 dB00
      27Locked256 QAM41447000000 Hz6.2 dBmV42.8 dB00
      28Locked256 QAM42405000000 Hz6.4 dBmV43.0 dB00
      29Locked256 QAM43411000000 Hz6.2 dBmV42.9 dB00
      30Locked256 QAM44417000000 Hz6.1 dBmV42.7 dB00
      31Locked256 QAM45423000000 Hz6.2 dBmV42.9 dB00
      32Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
      <tabindex=-1>Upstream Bonded Channels</tabindex=-1>
      ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
      1LockedATDMA15120 Ksym/sec35600000 Hz41.3 dBmV
      2LockedATDMA25120 Ksym/sec29200000 Hz41.5 dBmV
      3LockedATDMA35120 Ksym/sec22800000 Hz40.3 dBmV
      4LockedATDMA45120 Ksym/sec16400000 Hz39.5 dBmV
      5LockedATDMA55120 Ksym/sec39600000 Hz42.0 dBmV
      6Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
      7Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
      8Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
      <tabindex=-1>Downstream OFDM Channels</tabindex=-1>
      ChannelChannel IDIndicatorSubcarrier Zero FrequencyActive Subcarrier Number RangeTotal CodewordsUncorrectable Codewords
      137Non-Primary617.6 MHz1108 ~ 29872523582380
      20Other0 MHz0 ~ 000
      <tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
      ChannelUpstreamIsMutedRanging StatusSubcarrier Zero FrequencyActive Subcarrier Number RangeSymbols Per FrameTx Power
      1 Other0 MHz0 ~ 000 dBmV
      2 Other0 MHz0 ~ 000 dBmV
      Extended Upstream Transmit PowerEnable Extended Upstream Transmit Power
      Current System Time: 2022-01-06 07:09:33
      System Up Time: 20:14:53
    • FURRYe38's avatar
      Any progress on this?
      • ljmagyar's avatar
        ljmagyar
        Star
        In my case, no.  it worked well for a few days and now is back to dropping.  It appears that when the downstream signal gets below 5dBmV the modem wants to reset to get better signal strength.  It is absurd.
        In the last 12 hours it has rebooted at least twice.
  • I purchased this router from best buy originally but then saw it cheaper at Costco a week later and swapped em out. Had some issues getting the app to recognize that I was connecting the new router (issues with the app in general). I have a small condo (950 sq ft) fully integrated with smart almost everything. I have 23 devices connected, primarily 2.4ghz, but 3 wired and I really only use 5ghz for my phone and laptop when I’m not at my desk. I don’t know much about all the settings that can be changed online but the only thing I messed with on the app was enabling ipv6 and changing network names. I did check to make sure I was receiving adequate cable power and I am. When connected, everything works pretty great, wired connection at 1000/mbps (paying for 1200) and my Wi-Fi speeds are around 480-600mbps. But my devices and the app seem to go in and out and I really am just getting the impression that this a good all-in one unit for people who want to plug and go and have somewhat fast speeds with a decent amount of devices. The next one up (ax6000) is way too much of a price jump to risk trying to improve performance so I’m thinking about making the switch to a separate modem and router and seeing how that works. Hopefully Costco has a good return policy lol.
    • AnnoyedCAX30Uzr's avatar
      AnnoyedCAX30Uzr
      I would return it to Costco as soon as possible. The warranty is usually only 90 days for these types of items, but you should check with them...
      Unfortunately, before I realized it was the router itself (our Spectrum had been having outages and I was rarely home until the Christmas holidays), my 90 day return window closed. Sigh...
      • ljmagyar's avatar
        ljmagyar
        Star
        I've got great news!!!  I got mine working!
        Yeah, I brought it back to Costco and bought a Motorola MG8702 from Amazon.  It was delivered overnight, so I never lost any uptime except for installation and provisioning.
        The Nighthawk CAX30 is NOT - repeat NOT on the 90 window.  If you have one, return it to Costco for a full refund.  I brought mine in - no original packaging or anything.  Just the modem and power adapter.  No questions asked - full refund.
        Don't suffer any longer.  DUMP THE CAX30
