Orbi WiFi 7 RBE973
Nighthawk CAX30 I just downloaded v1.4.11.2
idealboy89
I just downloaded v1.4.11.2 from this page using my mobile internet and uploaded it to the router by logging into 192.168.1.1 and navigating to Advanced -> Administration -> Router Update
That fixed my internet connection instantly.
NOTE: v1.4.11.2 is a much older version of the firmware than the latest one.
Message 1 of 7
Accepted Solutions
idealboy89
Re: Nighthawk CAX30 I just downloaded v1.4.11.2
That is correct. I used the .bin file that was a part of the zip package
Message 7 of 7
All Replies
Guru
https://kb.netgear.com/000065543/My-Nighthawk-CAX30-Cable-Modem-Router-is-not-connecting-to-the-Inte...
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 7
That link appears at the top of the Community page for this section.
https://kb.netgear.com/000065543/?_ga=2.5970099.1073564255.1670756476-997256614.1625128861
Here at least, the link goes nowhere.
Not very assuring when when Netgear tries to alert people to a problem with a broken link.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 3 of 7
Bradylaura2000
After everything broke yesterday, I moved to another (used) router for different connection failures. turns out Xfinity says they have an issue in my area, then xfinity texts me about this workaround so I think “maybe it’s me, not them”... I roll back to CAX, but the TM trick doesn’t work, I default the router, still nope. Then I read I should roll back the code. I’m 20 hours into this, worked from home off my work phone that I’m limited on data with poor signal. I’ve had weird issues where individual devices would lose connectivity the entire life of this modem:router.
Then I dig into the code and there’s stats from this month/last month and other odd remnants… did it default all the way!? Is it really xfinity or is it this coincidental update?? Am I going in circles? I’m in IT, how would an every day joe handle this when I’m near melt down status!?
I wish Costco would recall this turd. Good luck everyone, and thanks to contributors for your time and thoughts.
Message 4 of 7
Guru
Downgrade the CAX30 to v1.4x if you still have WEB UI access to the modem. If you don't, try this to load the v1.4x FW file using a wired PC:
https://community.netgear.com/t5/Cable-Modems-Gateways/My-Nighthawk-CAX30-Cable-Modem-Router-is-not-...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBE971 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 5 of 7
trainwrek
Hi,
When I unzip the file, i see a .bin file (CAX30-V1.4.11.2.bin). But when I look at CAX30 manual, it mentions that the firmware file should be either a .img or .chk file. Just want to make sure that .bin file is the one that you upload via web UI to get the firmware version to 1.4
Thanks
Message 6 of 7
idealboy89
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 5360 views
  • 0 kudos
  • 6 in conversation
Announcements
Orbi WiFi 7
