- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk CAX30 - ISP Can see Router, but can't connect to Router via Ethernet or WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Very suddenly I cannot connect to my Router/Modem. My ISP, Xfinitiy, can see it, and I can even reset it through my Xfinity account.
However, I cannot connect to device itself. It doesn't show up when looking for wifi networks, can I can't connect to it via ethernet cable either. Tried multiple devices too. I've done a factory reset and that also hasn't worked. The router seems like it's gone totally dark. What do I try next?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk CAX30 - ISP Can see Router, but can't connect to Router via Ethernet or WiFi
What are all the led's on it doing?
Try disconnecting the coax from it and resetting it. Then reconnect the coax (as it'll enter a boot loop without the coax connected)
If that doesn't help, you might need to check if its still in warranty
