- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk CAX80 male barrel connector power plug size
- Mark as New
- Bookmark
- Subscribe
- Permalink
What size is the size of the male barrel connector on the DC power cable that comes with the CAX80 modem/router? It appears to be 7 to 7.4mm outer diameter, 5 to 5.1mm inner diameter. Does anyone know the actual size. The inner diameter should match the pim size of the connector input jack on the modem/router.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk CAX80 male barrel connector power plug size
Try looking at the spec sheet or the user manual to see if the plug size is listed. Or take a dial caliper measuring device to check the size.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Try looking at the spec sheet or the user manual to see if the plug size is listed. Or take a dial caliper measuring device to check the size.
Thank you, FURRYe38, I have gone through all of the documentation thoroughly, as have the Netgear Support people I have spoken with, to no avail. I will look for a caliper and give that a shot, but I am still hoping to get the official statement from Netgear. Even just knowing the diameter of the pin in the input connector on the CAX80 router/modem would help. Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you so much! One Netgear support person responded with the same size, 7.4 OD, 5.1 ID. I will proceed with this and see how it goes. As a note however another Netgear support person responded that it was 7.9 OD and 5.5 ID. This seemed too large base on the best MM stick measurements I could execute short of a caliper. I am also only findinng cunnectors available at 7.4mm OD and and even 5.0mm ID. I have orded two different brandsnat this 5.0mm ID size and will report back how it fits. Thank you again and to all others who have replied!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see that 7.4mm OD, 5.1mm ID is the Industry Recognized Mating Diameter and 7.4mm OD, 5.0mm ID is the actual diameter. So as I am learning more, all is good there.
