Orbi WiFi 7 RBE973
Reply
Nighthawk CAX80 restore settings from C7000v2 config file
milhan
Tutor
Hi,
I have a Netgear C7000v2 modem router and now got a Nighthawk CAX80 modem router. I saved the settings on the C7000v2 to a .cfg file so that I can use those settings on the new CAX80. But when I try to restore the .cfg settings file in CAX80 192.168.1.1 Advanced > Backup Settings > Restore saved settings from a file, I get "Error: Fail to restore."
Is there any way I can use the saved settings from the C7000v2 file on the CAX80?
Thank you
Message 1 of 3
Accepted Solutions
microchip8
Master
Re: Nighthawk CAX80 restore settings from C7000v2 config file
No. Different hardware and different firmware
Message 2 of 3
All Replies
microchip8
Master
Message 2 of 3
@microchip8 has answered your question.
The best approach I have found it to take screen shots (Alt + Print Screen) of the relevant pages.
Tedious, but it works.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 882 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
