Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk CM1200, slow speeds, partial service
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-12-16
11:37 PM
2022-12-16
11:37 PM
My CM1200 is a little more than a year old, bought for use with RCN Gig Speed internet.
The modem has always thrown errors in the logs, mostly this one:
Missing BP Configuration Setting TLV Type: 17.3;CM-MAC=38:94:ed:08:96:c8;CMTS-MAC=00:af:1f:1f:24:ee;CM-QOS=1.1;CM-VER=3.1;
But it never interfered with service so I ignored it.
However, several weeks ago my speeds dropped from around 950mbps to 19mbps. Restarting the modem will give 950mbps for a test or two, then drop back down to 19.
RCN says they can’t see anything wrong. They’ve sent a refresh signal several times but there was no change.
I noticed in the cable status section it says “partial service” under the downstream bonded channels. RCN said it looks like the modem needs to be replaced but I think it’s the outside wiring.
I’ve attached a screenshot of the cable status page.
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-12-16
11:41 PM
2022-12-16
11:41 PM
Re: Nighthawk CM1200, slow speeds, partial service
Also -
Hardware Version 1.01
Firmware Version V3.02.01
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-12-17
07:09 AM
2022-12-17
07:09 AM
you've got line issues.
Your power levels are through the roof. They should be between -7.5 and 7.5dbmv. You're over 15. Way to hot.
they'll need to check lines or turn down their power amplifier for your setup.
Or you can try adding in a 4-6x coax splitter in line to see if that'll drop the power enough. Or a signal attenuator.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 3
Announcements
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
