Orbi WiFi 7 RBE973
Reply
Nighthawk CM2000 & Orbi RBR40
Kristn
Keeps getting message no internet on iPads
When I look at orbi app on cell it has wifi info- orbi, at no time I didn’t put password for Nighthawk on anything, just plugged in
Lost 😞
Message 1 of 4
Guru
Re: Nighthawk CM2000 & Orbi RBR40
Do wired devices have internet? Or is it only these pads that have problems? Any other wifi devices exeperience problems?
Message 2 of 4
Kristn
I have wireless- wired into rather Orbi . We had a professional set up last year a modem (NetGear) with the Orbi
Comcast said my modem needed replaced too slow, they recommended Nighthawk CM2000
i did step by step like the Comcast said, plugged into Orbi
I did not have to put the password information the nighthawk anywhere.
I have to reset everything a few times a day because it says offline. It's only been since Friday, I haven't used the computer. Phones even said not internet connection.
 Orbi app under WiFi settings should it be nighthawk or Orbi.
Message 3 of 4
Guru
Sounds like it maybe a orbi system problem.
You'll need to wire connect a PC to the modem to see if the modem works there or exhibits any problems first. If it doesn't then your next step is to review the Orbi system.
Please visit and post about the Orbi RBR40 in the Orbi AC forum:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 760 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
