× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
Reply
No matter how long I do the factory reset
binhdan2904
I had the same issue. no hope , no matter how long I do the factory reset. Thinking about bought new cable mordem . so mad at neatgear
Message 1 of 4
Guru
Re: No matter how long I do the factory reset
So do you not get access to the setup wizard at 192.168.1.1 after you factory reset the modem for 10 second press on the reset button with a wired PC?
If you can gain access to the modems web page, be sure to downgrade the FW to v1.4x:
https://community.netgear.com/t5/Cable-Modems-Gateways/Nighthawk-CAX30-I-just-downloaded-v1-4-11-2/t...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
binhdan2904
Can NOT even get in 192.168.1.1, wifi death as well. There no way that I can access to the moderm
Message 3 of 4
Guru
I recommend you reach out to a forum moderator and ask for help there. RMA comes to mind if everything has been tried.
@DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 276 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
