Orbi WiFi 7 RBE973
Reply
Only 24 channels locking
Bmac1024
So basically talked to isp and they said i should be locked into all 32 channels and hes never seen this happen and told me to come here and ask for any answers?
Message 1 of 11
Guru
Re: Only 24 channels locking
What model modem is this?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-mode...
Power levels are a tad bit high:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
I seem some correctables that should be mostly zeros like the other channels.
Then try a factory reset on the modem with the ISP cable line disconnected. Power OFF the modem for 1 minute. Then reconnect the ISP coax line, then power ON. Check channels again.
Message 2 of 11
Bmac1024
thanks for help man, and its Firmware Version
V1.02.06 , I'm trying the reset and removing coax now ill brb
Message 3 of 11
Bmac1024
after the factory reset and unplugged
Message 4 of 11
Guru
Please post a copy and paste of the modems event log page.
Message 5 of 11
Bmac1024
Message 6 of 11
Guru
Those criticals needs to be reviewed by the ISP and resolved. They indicate a signal line issue.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
Might try a different modem and see. The CM700 is getting up in age and maybe a newer generation maybe needed.
Message 7 of 11
Bmac1024
thanks hopefully they run new drop and coax to the modem for me and try that.
Message 8 of 11
Guru
Could try the modem at a different location as well, like at a friend, neighbor or families place to see if problem follows or not.
Message 9 of 11
Bmac1024
good idea thx
Message 10 of 11
Guru
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 785 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
