Orbi WiFi 7 RBE973
Reply
PS4 not connecting to functioning wifi, but works on hotspot
wally913
My wifi connects to every device beside my ps4 and I already tried resetting both router along with the ps4.
my wifi's ssd doesn't even show up on my ps4. what do I do?
Message 1 of 4
Guru
Re: PS4 not connecting to functioning wifi, but works on hotspot
Not much to go on.
There a NG product and model your referring too?
Message 2 of 4
wally913
It's a Netgear c6300v2. my network doesn't show up on my ps4 and when I manually try to connect it fails to obtain the ip address. Although my ps4 works with my iPhone's hotspot the weird thing is that the network shows up on all but the ps4.
Message 3 of 4
Guru
Does the PS console connect to the modem using a ethernet connection to the back of the modem?
How is the wireless configuration setup?
What security mode are you using on wifi?
What channels are you using?  Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Contact Sony for additional help and support regarding there product.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 426 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
