Orbi WiFi 7 RBE973
Reply
Port forwarding isn't working
Timebomb41
So I don't know if this is in the right place but, i've been trying to portforward my N300 WiFi Cable Modem Router Model C3000 and when I check to see if the ports are open it says they are not open help?
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: Port forwarding isn't working
Hello Timebomb41
Here is the article on how to port forward on your router just follow the steps and find the correct Ip address of the device you need these ports on. Let me know if you have any questions or tell me what service your trying to forward I may be able to forward help.
http://kb.netgear.com/app/answers/detail/a_id/24290
DarrenM
Message 2 of 4
Timebomb41
That did not work is there anything else I could try to get it to work?
Message 3 of 4
DarrenM
You could put the device in the DMZ and see if that works. I did also find a good website that has a list of all the things that could be causing the issues with the port fowarding take a look at this.
http://www.pcwintech.com/common-problems-fixes-port-forwarding
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3862 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
