Orbi WiFi 7 RBE973
Reply
Power Blip Factory Reset Modem/Router Nighthawk AX6 CAX30
GreenGMC
Had a power blip at my house. My modem/WiFi router reset to factory settings. Nighthawk app is useless and won’t connect. Now I have to reset the modem/router and dozens of devices and connected plugs. I will not buy a NetGear device again.
Message 1 of 5
Kitsap
Master
Re: Power Blip Factory Reset Modem/Router Nighthawk AX6 CAX30
Not true at all.  If you use the exact same SSID and password when you reset, your IoT devices will reconnect automatically.  When your router was running satisfactory, did you happen to save off a configuration file?  Maybe you should explore that option as it makes a firmware default reset reasonably easy to configure by importing a previous configuration file.
Agree, attempting to configure or trouble shoot a gateway using a mobile device application is a waste of time.
Message 2 of 5
Unfortunately, this is a consequence of flaky power. No brand will be immune to that sort of thing. The good news is that your device survived the blip. Many don't.
As well as setting up the device as @Kitsap has suggested, which will restore everything to the previous state, there is an even easier way of going about things than changing any settings on the modem/router itself.
How do I back up the router configuration settings on my Nighthawk router? | Answer | NETGEAR Suppor...
Then, after the thing resets itself you just go through the "restore" process and end up where you were before the power went off.
It is a  pity that so  many people seem to miss this essential recovery measure.
Message 3 of 5
GreenGMC
Power went off for five minutes overnight, and this has happened again. At first some mobile devices could connect to the WiFi and had sporadic internet connection. Now no mobile devices or IoT devices can connect to the router, and even the hardwired Arlo/NetGear camera router that is hardwired to the NetGear router isn’t connecting to the internet. I’ll look into backing up my configuration, but I’ll be looking for a different brand router.
Message 4 of 5
The usual reply when this happens is to ensure that you reboot the whole network in the correct order. But that is kind of difficult when you have a combined modem/router.
Bit late to back up the configuration. You should have a copy there of that already so that you can restore the configuration after this happens.
As to another device, experienced users prefer separate modems and routers. CAX devices are better than some with their separate router firmware, but it still doesn't have the flexibility of a modem followed by a router, which gives a much bigger choice of options.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1115 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
