Orbi WiFi 7 RBE973
Reply
Product to purchase
webs2011
Product to purchase
I have a cox panoramic wifi gateway (gigablast).  I have both hardwired and wifi used in my house.  I am looking at putting a firewall appliance that would be installed behind the gateway from cox, but would monitor/protect both my hardwired connections and wifi connections.  I also have several TVs that utilize the cox wifi.  Would like recommendations on products to purchase.
Thank you,
Message 1 of 3
Guru
Re: Product to purchase
This a cable modem forum for NG only. Only discussion about cable modems and gateways made by NG are posted here.
I recommend you post over in the ISPs forum about there products and use of them.
IF your looking for firewall products, I would do a search online for firewall appliance devices.
Good Luck.
Message 2 of 3
webs2011
Thank you.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 407 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
