Orbi WiFi 7 RBE973
Reply
R7000 Tx rate is alway 54Mbps
shaulch
Tutor
Hi,
Till now, i didn't have any issue but now every device (Macbook , Ipad, Iphone, PC) is connected on 5Ghz but TX is 54Mbps.
RSSI :  -37dbm
Noise : -95dbm
Phy mode: 802.11ac
Firmware: V1.0.9.88_10.2.88
Encryption - AES
Reboot , firmware upgrade , change channels  - nothing . I alway receive 54Mbps (so in speedtest i get 30Mbps on 1GB Internet connection)
`Any idea ?  is it HW issue ? SW issue ?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 4
Guru
Re: R7000 Tx rate is alway 54Mbps
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck.
Message 2 of 4
shaulch
Tutor
Answer myself,
Looks like some firmware upgrade remove the check from WMM checkbox .
I enabled WMM (Wifi Mulitimedia) in Qos menu and boom , the link TX speed increased.
Message 3 of 4
Guru
Enjoy. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1788 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
