Orbi WiFi 7 RBE973
Reply
R8000p X6S Slow ethernet speed
Davey2240
I actually have Model R8000P AC4000  Anyway if I hook my ethernet up from my modem directly to my computer I download at 450Mbsp going thru my router I only get between 95 and 115Mbsp. Why is the router not recognizing my actual IP speed?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: R8000p X6S Slow ethernet speed
What firmware version are you on? have you tired to factory reset the router?
DarrenM
Message 2 of 3
Davey2240
Hi Darren
Firmware Virsion V1.4.1.30_1.2.26 and yes I did a factory Reset twice. I do believe I figured out the problem. I was using an older Linksys switcher, when I upgraded that with a new 8 port switcher with gigabyte technology I have all kinds os speed now. 495 Mbsp down load and 23.5 Mbsp upload. I just installed the switcher last noght.
Thank You
Dave C
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1027 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
