Orbi WiFi 7 RBE973
Reply
Readyshare files wrong format
Xerotao
Follower
Hi guys
I am having an issue with my readyshare on my D6200.
Some mp4 movies i copy to my harddrive does not show in videos on the readyshare. But instead is found in music folder as m'4a format.
Never had this issue with my old DGND4000. Infact its happening to both my D6200's.
Have tried resetting both mode/routers. Different usb drives/thumbdrives in different file systems.
Any help would be appreciated.
Model: D6200|Dual Band 11ac ADSL Modem Router
Message 1 of 2
antinode
Guru
Re: Readyshare files wrong format
   And you chose this "Cable Modems & Routers" forum instead of an
appropriate "DSL Modems & Routers" forum for this?
      https://community.netgear.com/t5/x/bd-p/home-dsl-modems-routers
> readyshare. But instead is found in music folder as m'4a format. [...]
   "copy" how, exactly?
   ReadySHARE may be garbage, but I doubt that it's capable of
converting video formats (to audio-only) on its own, and then storing
them in some location of its own choosing.  For only "Some mp4 movies".
I suspect that your problem (whatever it might be) lies elsewhere.
> [...] Different usb drives/thumbdrives in different file systems.
   "different file systems"?
   What happens if you do whatever you're doing, but specifying a
locally-connected (USB?) destination, instead of a remote ReadySHARE
destination?  Blame assignment is job one.  Is the problem with
ReadySHARE, or with what you're doing with it?
   When I tried to post this, I got a (nonsensical) complaint:
      The message body contains M-4-A, which is not permitted in this
      community. Please remove this content before sending your post.
Where I've added the hyphens in "M-4-A".  I'll assume that that explains
the spurious apostrophe in your "m'4a".
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 603 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
