× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
× NETGEAR would like to hear from you about specific features so we can improve your experience. To participate in this survey please click HERE.
Reply
Readyshare showing up as an Attached Device
ng7457
Follower
Hello,
This is a post about a NightHawk AC1900 Wi-Fi Cable Modem and Router, model C7000 v2.
My Readyshare server is not enabled in the advanced settings of my router, and I have not set up any share folders or even connected a USB device to my router to act as a storage device.  However, starting just yesterday, my Readyshare (Internal server) started showing up in my list of Attached Devices as a Wired device that is attached to my router.  This also makes the Readyshare server show up in my arp table on my Windows 10 box.
(1)  Like I say, this just started happening yesterday, and before this, my Readyshare server did not show up as an attached device on my router or in my arp table on my Windows 10 box.  I would like to completely disable this functionality so that it does not show up as an attached device for my router at all and so that the Readyshare server for my router does not show up in my arp table for my Windows 10 box.  (I do not wish to use the Readyshare functionality with my router.)  How do I do this?  (Again in the Advanced Settings page of my USB Storage for my router, which corresponds to my Readyshare server, I do not have any of the available Readyshare sites/links enabled, and all are also set to be password protected with my Admin password that I use to login to my router.)
(2)  Finally, I have read that the Readyshare functionality has some kind of memory overflow vulnerability.  Could someone be exploiting this vulnerability in some way to make my Readyshare server suddenly start showing up as an Attached Device on my router?  Please advise me about this because I am most concerned about shutting down Readyshare as a vulnerability as best I can.  Unfortunately, since this is also a cable modem and not just a router, and my ISP is actually the one that controls what firmware version is used for the Cable Modem router that I have. Currently, my ISP is running firmware v. 1.02.09 for my cable-modem/router.
Thanks in advance for any help with these questions.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 7
Guru
Re: Readyshare showing up as an Attached Device
Has a factory reset and setup from scratch been performed yet?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Routerand RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700, EX7500/EX7700
Message 2 of 7
fullbright
I just wonder if you found a permanent solution to this issue.
Message 3 of 7
olympos1625
NETGEAR Employee Retired
HI @fullbright,
Welcome to NETGEAR Community!
Thank you for reaching out. Are you having a similar issue as well? Do you have the same cable modem model?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
Message 4 of 7
fullbright
Yes, I have the same problem.
Message 5 of 7
fullbright
I also made another post about this problem. You can check "Re: wired readyshare"
There are many other posts in this community forum but there is no clear working solution at all.
Message 6 of 7
olympos1625
Hi @fullbright,
Our support team is looking into this issue and would like to work with you
We would like to endorse you to NETGEAR Level 2 support team for a callback. Please DM the following information:
Name:
Email:
Phone:
Preferred schedule (at least 2 days ahead)
Timezone:
Device S/N:
Alternatively, if you wish to be contacted via email only then kindly include your preferred email address.
I am looking forward to your response.
Oliver
Community Team
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 751 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
