- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Replace Qwest Q1000 modem with NETGEAR Nighthawk AC1900 (24x8) DOCSIS 3.0 WiFi Cable Modem Router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will the Nighthawk AC1900 (24x8) DOCSIS 3.0 WIFI Cable Modem Router replace my Qwest Q1000 modem without any problems?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Replace Qwest Q1000 modem with NETGEAR Nighthawk AC1900 (24x8) DOCSIS 3.0 WiFi Cable Modem Route
You need to ask your ISP to check to see if it's officially supported on there network. If it is, then you'll be fine.
Review the C7000 spec sheet for details to compare agains the Q1000:
http://www.downloads.netgear.com/files/GDC/datasheet/en/C7000.pdf
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will _any_ cable-TV-type ("DOCSIS") modem+router replace _any_ DSL
modem+router "without any problems"?
No.
Why do you want to replace your Q1000?
Note that "Nighthawk AC1900 (24x8) DOCSIS 3.0 WIFI Cable Modem
Router" is not a model number, and your "Qwest Q1000 modem" is actually
an Actiontec Q1000 modem+router.
https://www.centurylink.com/home/help/internet/modems-and-routers/actiontec-q1000.html
Yes, CenturyLink calls it a "modem", but it's a modem+router.
> You need to ask your ISP [...]
Not really.
> My Setup [...]
Just as useful as the "ask your ISP" advice. Thanks for the clutter.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not very tech minded when it comes to these things, but I thought I need to upgrade my modem/router because of all the equipment we now have in the house that needs wifi. Door bell, games, computer, ipad, etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] I thought I need to upgrade my modem/router because of all the
Is there some actual problem which you are trying to solve?
A device like a door-bell may use very few resources when it's idle.
Depending on the level of your DSL service, there's no particular reason
to believe that the Q1000 is your bottleneck.
Even if the Q1000 were a problem, it's a DSL modem+router, not a
"Cable" modem+router, so a C7000 (or anything else with "DOCSIS" in its
description) would not be a drop-in replacement, if you expect to keep
your DSL service.
And that's why it pays to explain the actual problem which you are
trying to solve, instead of asking how to implement some particular
"solution" which may or may not make much sense.
- Mark as New
- Bookmark
- Subscribe
- Permalink
it wont work. Dont buy C7000.
Qwest modem is "DSL modem".
C7000 is a "cable modem"
two different technologies.
if you get on xfinity Comcast then C7000 will work.
