Orbi WiFi 7 RBE973
Reply
Slow Speeds - Xfinity Gigabit Internet
CooyonLA
Looking for help:
Since i upgraded to gigabit service with xfinity, I haven't topped 100mbps download speeds. I'll provide my cable connection stats below to see if someone can provide input. After researching for hours, I've realized that majority of my connections are pretty good. The only thing that sticks out is the correctable Downstream OFDM Channels. I don't really understand what that means, I'm just trying to figure out the culprit of the slow speeds (wiring of my house or a technical issue that can be resolved with Xfinity/Netgear support)
Stats below:
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
<tabindex=-1>Startup Procedure</tabindex=-1>
ProcedureStatusComment
Acquire Downstream Channel645000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnableBPI+
IP Provisioning ModeHonor MDDIPv6 only
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
ChannelLock StatusModulationChannel IDFrequencyPowerSNR / MERUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1LockedQAM25637645000000 Hz4.8 dBmV41.4 dB58682858600
2LockedQAM2569477000000 Hz7.1 dBmV42.8 dB58559626700
3LockedQAM25610483000000 Hz7.0 dBmV42.8 dB58560035100
4LockedQAM25611489000000 Hz7.0 dBmV42.8 dB58560430400
5LockedQAM25612495000000 Hz7.1 dBmV42.9 dB58560799100
6LockedQAM25613501000000 Hz7.1 dBmV42.8 dB58561106200
7LockedQAM25614507000000 Hz7.1 dBmV42.8 dB58561538200
8LockedQAM25615513000000 Hz7.3 dBmV42.7 dB58561864700
9LockedQAM25616519000000 Hz7.2 dBmV42.7 dB58562427800
10LockedQAM25617525000000 Hz7.3 dBmV42.8 dB58562782700
11LockedQAM25618531000000 Hz7.3 dBmV42.8 dB58563165500
12LockedQAM25619537000000 Hz7.2 dBmV42.8 dB58563555700
13LockedQAM25620543000000 Hz7.1 dBmV42.7 dB58563922600
14LockedQAM25621549000000 Hz7.2 dBmV42.6 dB58564227000
15LockedQAM25622555000000 Hz7.0 dBmV42.5 dB58564715500
16LockedQAM25623561000000 Hz6.9 dBmV42.3 dB58565050900
17LockedQAM25624567000000 Hz6.6 dBmV42.3 dB58565688400
18LockedQAM25625573000000 Hz6.4 dBmV42.3 dB58566079800
19LockedQAM25626579000000 Hz5.9 dBmV42.1 dB58566471300
20LockedQAM25627585000000 Hz5.8 dBmV42.0 dB58566821900
21LockedQAM25628591000000 Hz5.8 dBmV41.9 dB58567172500
22LockedQAM25629597000000 Hz5.5 dBmV41.6 dB58567566000
23LockedQAM25630603000000 Hz5.3 dBmV41.5 dB58567909200
24LockedQAM25631609000000 Hz4.9 dBmV41.5 dB58568225000
25LockedQAM25632615000000 Hz4.4 dBmV41.3 dB58568691500
26LockedQAM25633621000000 Hz4.2 dBmV41.1 dB58568976000
27LockedQAM25634627000000 Hz4.2 dBmV41.1 dB58569365100
28LockedQAM25635633000000 Hz4.4 dBmV41.0 dB58569810200
29LockedQAM25636639000000 Hz4.5 dBmV41.0 dB58570153500
30LockedQAM25638651000000 Hz4.8 dBmV41.2 dB58570338300
31LockedQAM25639657000000 Hz4.8 dBmV41.4 dB58570453900
32LockedQAM25640663000000 Hz5.1 dBmV41.4 dB58570641000
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
1LockedATDMA135800000 Hz47.3 dBmV
2LockedATDMA229400000 Hz47.3 dBmV
3LockedATDMA323000000 Hz47.3 dBmV
4LockedATDMA416600000 Hz47.3 dBmV
5Not LockedUnknown00 Hz0.0 dBmV
6Not LockedUnknown00 Hz0.0 dBmV
7Not LockedUnknown00 Hz0.0 dBmV
8Not LockedUnknown00 Hz0.0 dBmV
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier Number RangeUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1Locked0, 1159690000000 Hz5.7 dBmV40.0 dB1246 ~ 284944208858799417390
2Not Locked000 Hz6.4 dBmV0.0 dB0 ~ 4095000
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
1Not LockedUnknown00 Hz0 dBmV
2Not LockedUnknown00 Hz0 dBmV
Any feedback would be greatly appreciated!
Model: CM1000|Ultra-High Speed Cable Modem—DOCSIS® 3.1 Ready
Message 1 of 6
CooyonLA
Re: Slow Speeds - Xfinity Gigabit Internet
Just realizing it cut off
Correctable Codeword= 9941739
Message 2 of 6
Guru
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Message 3 of 6
Guru
How are you testing this?
do you have a pc hardwired into the modem?
What pc is it? Is it a gigabit pc?
Have you checked the cable to ensure it supports gigabit? standard cat5 doesnt. Cat5e does
What site are you speedtesting on?
I've had the isp provision a modem wrong. Might be worth checking with xfinity to ensure it has the proper provisioning.
Message 4 of 6
CooyonLA
Hi,
I run speed tests through speednet, xfinity app, etc. Turn my VPN on and essentially same results
Yes, I hardwired into my modem. I'll get about 105mbps hardwired to modem. 95mbps hardwired to router
I have a brand new PC I-7 9700K with gigabit capabilities. I ran a cat 6e wire from my router, into the attic, to my office about 3 weeks ago to see if that would help. I had the Netgear Powerline adapter's before and honestly think i was getting better speeds (130mbps) using the adapters.
And i will reach out to xfinity about the provision.
Just a little background information. I bought my house in July 2019. The previous homeowner stated that he had xfinity service. So, I placed a contract online and hooked up my own equipment. I'm thinking that the cable wiring might be old/outdated. The wiring runs around the perimeter of the house with cable entries into my kitchen, living room, and 2 bedrooms. So might be too many splitters?
Message 5 of 6
Guru
do you have another device you could test right at the modem? plus then you can also try different ethernet cords to make sure it isn't a wire issue.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1290 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
