× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
× NETGEAR would like to hear from you about specific features so we can improve your experience. To participate in this survey please click HERE.
Reply
Spectrum compatible Cable Modem
Ferroid
Tutor
I'm currently shopping for a new cable modem for my Spectrum service and wanted to get some input on two different models of Netgear modems. I don't have voice service and don't need a router so I've narrowed the choices to the CM1000 and CM1100. I also found a reference online to a CM1200 model that I don't find on Netgear's product pages. Any opinions on which modem to purchase?
Thanks!
Model: CM1100|Nighthawk Multi-Gig Speed Cable Modem—DOCSIS 3.1
Message 1 of 5
Guru
Re: Spectrum compatible Cable Modem
Any of the CM models will work if your ISP supports them.
You need a router behind the CM modems as they don't support router or wifi. So if you have a router already, then either one of thes models will connect up to the external router.
The CM1200 is mostly meant for businesses, not home. Depends on what ISPs will supprot for it:
https://www.netgear.com/support/product/cm1200.aspx
The 1100 is a good modem FYI.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 5
Ferroid
Tutor
I am considering using a 3-point Google WiFi mesh network with it.
Message 3 of 5
Guru
Any non-gateway router will work with a CM modem. So yes, that would work.
Message 4 of 5
FLUXFLINCH
This may help : Best Modem For Spectrum
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3914 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
