Orbi WiFi 7 RBE973
Reply
Stuck in Router Password Recovery mode using Chrome
sheaves99
This problem just started yesterday.  Whenever I try to get to routerlogin.net with Chrome I get stuck in a Router Password Recovery loop that constantly asks for my serial number (which I successfully fill in) and my security questions (again successfully fill in).  After answering the security questions, my browser immediately goes back to the Router Password Recovery screen.  I have tried turning off googles password auto signin feature and I have cleared the browsing data.  Nothing works.  I can successfully login to my router using Firefox or Edge without getting stuck on the Router Password Recovery page, but not with Chrome.  Any suggestions?
Model: C3700|N600 Cable Gateway Docsis 3.0
Message 1 of 3
Accepted Solutions
Guru
Re: Stuck in Router Password Recovery mode using Chrome
It seems to have been a problem with the update to chrome 77 and netgears gui.  Some have reported that if they reboot their computers, it fixes the issue.
otherwise most have had to use chrome canary, edge, or firefox until the chrome team and netgear team figure out a resolution.
https://community.netgear.com/t5/Orbi/Chrome-77-breaks-orbi-login-page/m-p/1799323#M70349
Message 2 of 3
All Replies
Guru
Message 2 of 3
sheaves99
Thanks.  That did work.  After shutting down and powering back up, I was finally able to login to my router.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4392 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
