× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
Reply
There are separate ssids and key paswords on my cg3000d router
6gkids
I see two separate default network names (ssid) and two separate key passwords. One is supposed to be for wired networek and one for wireless?  Do I use one for an ethernet connected pc, and the other for connecting my mac laptop to wireless?  Windows 7 home premium, and Macdbook pro
Message 1 of 3
Accepted Solutions
6gkids
Re: There are separate ssids and key paswords on my cg3000d router
Ok. I did find out I could not use the wifi setting without entering the admin password, but I used DHCP and it automatically set up fine.
Message 3 of 3
All Replies
TheEther
Guru
The CG3000D only has one Wi-Fi network, therefore, only one SSID.
There are no passwords required for wired devices to connect to the network and access the Internet.
The only passwords used in conjunction with routers are administrative passwords to log into the router and Wi-Fi passwords to connect to the wireless network.
Message 2 of 3
6gkids
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3336 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
