Orbi WiFi 7 RBE973
Reply
Unable to access cable modem C6250
Tybotim
I cannot access C6250 AC1600 modem. Using IP address, WWW.routerlogin.net & .com open Netgear website. Nighthawk is no use. Originally set up with genie. Modem will only connect to pc not mobile devices or roku. Tried reboot and reset to no avail. Any insight would be appreciated.
Model: C6250-1AZNAS|AC1600 WiFi Cable Modem Router
Message 1 of 3
Accepted Solutions
Tybotim
Re: Unable to access cable modem C6250
Problem resolved. Nighthawk finally worked.
Message 2 of 3
All Replies
Tybotim
Message 2 of 3
Guru
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1036 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
