Orbi WiFi 7 RBE973
Reply
Unable to disable AP isolation
prasanth5reddy
Follower
I am trying to connect my google home mini to wifi from this modem router, but it says to disable ap isolation. I have searched everywhere in the advanced section of netgear genie portal, but couldn't find it. If anyone knows how to troubleshoot this, please reply. TIA
Model: C3700|N600 Cable Gateway Docsis 3.0
Message 1 of 2
Guru
Re: Unable to disable AP isolation
Anything under Basic Tab/Wireless settings or Advanced Tab/Advanced Settings/Wireless Settings
Is your setup mobile device connected to the 5Ghz radio or the 2.4Ghz radio. If the 5Ghz radio is being used for the setup mobile device. Connect to the 2.4Ghz radio with your mobile phone/pad.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3217 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
