Orbi WiFi 7 RBE973
Reply
Unregister Modem
Karaptian
Unregister Modem
When I originally purchased my CM500 modem, I registed it with Netgear.
The product is no longer under warranty and I don't use it.
I gave the modem to a family member. They tried to use it with Cox Cable ISP, however, Cox is telling the family member that it needs to be unregistered.
How do I do that?
Model: CM500V|Cable Modem for Internet & Voice–DOCSIS 3.0
Message 1 of 2
Guru
Re: Unregister Modem
You would need to contact the prior ISP where that modem was used and have them remove it from there system.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 484 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
