Orbi WiFi 7 RBE973
Reply
Upstream light blinking, spotty internet
drmsi9292
Hello,
I've had Xfinity internet for about a week now. Things had been fine until this morning, seems my upstream light is blinking and my connection is mediocre. I still have internet, but anything requiring a stable connection (ex gaming) has noticable interruptions. I can further see the issues by pinging Google and watching timeouts roll in consistently at varying intervals.
My line has no splitters or any other devices on it- only thing I can think of that could be my issues versus my ISPs is that the tech installed a needlessly long coax cable between the drop and my C6220, like 15 feet long. I'm planning to run out and buy a shorter coax cable just to ensure that's not the issue, but I thought I would drop my Cable connection status and event log in case something else stuck out.
Thanks for any assistance!
Model: C6220|DOCSIS 3.0 High Speed WiFi Cable Modem Router
Message 1 of 4
drmsi9292
Re: Upstream light blinking, spotty internet
Attaching Images again since the in-line ones seem to not work
Message 2 of 4
drmsi9292
Message 3 of 4
Guru
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1603 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
