Orbi WiFi 7 RBE973
Reply
Use of C7000v2 in India which is purchased in the US
Laxmikanth
Follower
Hi,
I have purchased "NETGEAR Nighthawk WiFi Cable Modem Router Combo (24x8) AC1900 DOCSIS 3.0" in the US and have been using it for the Xfinity/Comcast. I am moving to India and would like to know if I can use the same modem router in India for the cable wifi connection.
Thanks
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 4
Guru
Re: Use of C7000v2 in India which is purchased in the US
You would have to ask the ISP in India if they support this model modem on there network.
Message 2 of 4
suyash271
Hi,
did it worked in India?
I have same model and i will be going back to India soon.
Message 3 of 4
Guru
@suyash271 wrote:
Hi,
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1108 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
