× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
Reply
Warranty
Cj48060
Warranty
So I purchased this in May off of amazon to take away the rental equipment fees from xfinity. Has worked great up until now. I cannot connect to my phone or ps4. My boyfriend called xfinity which the internet bill is under and than everything checked out ok on their end than directed him to net gear. They basically told us we needed to renew our warranty on the product. Makes no sense to me. I've looked over every single detail on Amazon and even on net gear website and there is nothing that states to pay money for renewal. Now I'm stuck with this product that is basically useless??
Message 1 of 4
Guru
Re: Warranty
No much help here.
What NG product and model# are you referring too?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
Cj48060
Re: Warranty
Hello, I'm sorry I guess I failed to mention the actual product. I'm new to this. But it's a AC1750 WiFi Cable Modem Router (C6300v2) if that helps, thank you kindly.
Message 3 of 4
Guru
Re: Warranty
Has a power off for 1 minute then back ON with the ISP modem been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-mode...
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 179 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
