Orbi WiFi 7 RBE973
Reply
Wifi no internet C7000 v2
rvint
Hello- Wifi was working last evening and no connection this morning.
I have power cycled several times as well as hard reset 3 times. My desktop is hard wire connected and has internet. I can connect to wifi but no internet service. I do show led on the router wifi on and 2.4 and 5 G all random blinking. I have turned the wifi off and on several times with the button on the router front.
Any direction would be helpful= Thanks
Message 1 of 6
Accepted Solutions
rvint
Re: Wifi no internet C7000 v2
Message 5 of 6
All Replies
Guru
Message 2 of 6
rvint
Thanks for the thought.
I did do a hard reset with no luck. I will try erase, power off overnight and try fresh in the morning.
Message 3 of 6
Guru
Message 4 of 6
rvint
Working- Thanks!
Message 5 of 6
Guru
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 828 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
