Orbi WiFi 7 RBE973
Reply
allowed devices not currently connected to the network for CAX30
ap958
Follower
How to get the devices on the allowed list TO the connected list. Unfortunately the internet has no solution to this problem, despite other products having the same issue.
Mine is the CAX30.
Message 1 of 2
Guru
Re: allowed devices not currently connected to the network for CAX30
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 571 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
