daleejr's avatar
daleejr
battery light for C7100V
Had a 75 minute power outage last morning. The battery was fully charged. Almost a day and a half later the battery light is still blinking. I should take this long to recharge since it was only in standby 75 minutes. Any ideas? Thanks
  • adod's avatar
    adod
    NETGEAR Employee Retired
    Hello, can you please login to the GUI and provide the battery status screenshot? Is your phone line hooked? Please let me know. Thanks, A
    • daleejr's avatar
      daleejr
      Screnshot is attached.  Phone line is hooked.  The battery light is flashing fast. Thanks.
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        Did the blinking ever stop?
        DarrenM
