Orbi WiFi 7 RBE973
Reply
c3000 Super slow speeds comcast.
spamsucks
So I changed to this device after my cable modem was dropping so often, and comcast was quick to get it running with no interaction at all... just the3 automated things. With this new modem in place, I see about 7mbps down and 3mbps up. If I plug my comcast router back in I see 93mbps down and 11 up.
Any thoughts? I am using all the same equipment otherwise... This is what the c3000 looks like fromthe provisioning end. Called comcast and they are sending someone, as they could not figure it out on the phone
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel615000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnabledBPI+
IP Provisioning ModeHonor MDDhonorMdd(4)
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM2569615000000 Hz1.9 dBmV41.4 dB00
2LockedQAM25610621000000 Hz1.9 dBmV41.4 dB00
3LockedQAM25611627000000 Hz2.1 dBmV41.5 dB00
4LockedQAM25612633000000 Hz2 dBmV41.4 dB00
5LockedQAM25613639000000 Hz2.1 dBmV41.4 dB00
6LockedQAM25614645000000 Hz2 dBmV41.4 dB00
7LockedQAM25615651000000 Hz2.1 dBmV41.4 dB00
8LockedQAM25616657000000 Hz2.1 dBmV41.4 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA15120 Ksym/sec36500000 Hz45.5 dBmV
2LockedATDMA25120 Ksym/sec30100000 Hz48 dBmV
3LockedATDMA35120 Ksym/sec23700000 Hz48 dBmV
4Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
Model: C3000|N300 Cable Gateway Docsis 3.0
Message 1 of 2
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: c3000 Super slow speeds comcast.
Hello Spamsucks
Have you checked with the cable company that the modem is provisioned correctly because it sounds like the c3000 is on a separate plan if you can still plug in your other modem and its working.
DarrenM
Message 2 of 2
All Replies
DarrenM
Hello Spamsucks
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3973 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
