Orbi WiFi 7 RBE973
Reply
c6300 can only connect wifi or extender
COUNTRYBOY1
Follower
I have a C6300 router which has been working perfectly. added a netgear extender. now I can only connect to one or the other. connect the extende to wi fi and it drops my routrer on my computer. when I go to wifi I cannot connect them both. I have windows 10
Message 1 of 3
Guru
Re: c6300 can only connect wifi or extender
what extender did you install?
How did you setup the extender? Using wps?
Message 2 of 3
@COUNTRYBOY1 wrote:
I have a C6300 router ...
That's a modem/router. If you can't fix it following advice from @plemans you could also try the right section for your hardware.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 509 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
