- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
can't connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
can't connect
I have 2 desktops.one close by connects with the internet. The second has a long cable, about 30 ft. long. The second now comes up as limited access and I get an Isp starting with169.254 Etc. meaning no or poor connection. It worked fine on the Ubee moden from Time-Warner but not on the netgear modem. I tried cleaning the contacts and changing ports to no avail. When I plugged it back into the Ubee (before I had the WIFI disconnected) it would connect. It used to work on my old DSL also. Been trying everything I know for months, by no success. Ready to go back to the Ubee. Can anybody help me ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: can't connect
Welcome to the community, @jrzradi
What's the exact model number of the NETGEAR device?
If you plug the cable to the port, do you get a light on the NETGEAR device to where you connected it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: can't connect
C3000. Yes, the green light was on. I found the Issue My ethernet cable of 50 ft. had too much resistance for the Netgear (though it worked fine with the Ubee & DSL). I replaced it with a new cat6 cable & it now works. Fortunately, I got it at 80% off at a Radio Shack store closing. So it seems the Netgear does have a very strong ethernet signal amplification I guess you get what you pay for.
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
