- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
cm1150v issue with phone service and speed.. xfinity
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have spent a few hours, 2 different times with xfinity operators trying to fix my modem issues. No phone and can not reach my subscription speed (600) but the first is more important. Tried a number of modem reboots. The phone icon on the modem lights for a second after rebot but ultimately goes out. Xfinity dude in India was useless. Is there something I am missing? THey want to send a tech out to my house and charge me money. I think this is xfinity getting back at me for ditching their modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: cm1150v issue with phone service and speed.. xfinity
xfinity can be an issue.
1. log into the cm1150v and get a screen snip of the cable connectin page and the logs.
2. if you have any splitters, amplifiers, attenautors in your line, remove them.
3. preferably, directly connect the modem to right where the coax enters the home. this prevents the wiring in the home from being the issue.
Comcast is great at making it challenging for people who use aftermarket modems. But if you can do your best to ensure it isn't something in the home, then it limits what the issue can be. by direct connecting it to where the coax enters and seeing if you still have the issue it usually means either the line is bad, their cmts is bad, or the modem is bad.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am unsure which screen you need.
- Mark as New
- Bookmark
- Subscribe
- Permalink
FYI.. My old comcast modem did have a voice line but we ditched that a number of years ago. They are just being diffucult.
- Mark as New
- Bookmark
- Subscribe
- Permalink
click on the cable connection tab above the voice tab you were on
- Mark as New
- Bookmark
- Subscribe
- Permalink
I feel like I am giving everyone my banking information... Is this ok?
- Mark as New
- Bookmark
- Subscribe
- Permalink
it doesn't have any account info on it. it shows the connection back to the isp. if you doubt this, search the forums, its kind of needed to check the connection.
I included an example of what it looks like off a c6300.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok.. pants down 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your signal doesn't look to bad.
How are you testing speeds?
What device do you have connected to the modem to test speeds?
If its a router, disconnect it and directly connect a pc to it. (it has multiple ethernet ports but you can only use 1 at a time through comcast unless you have wan port aggregation on the router)
try dslreports.com and speedtest.xfinity.com
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a netgear router after the modem. AC1200. I tested speeds through that.. Its rated for 600 download. I have tested both diret to modem and through the router. Speed is the least of my issues.. I want phone. My xfinity account has a phone number listed and active. Does it have something to do with the starting frequency being "0"
- Mark as New
- Bookmark
- Subscribe
- Permalink
test speed are 230 to 250
- Mark as New
- Bookmark
- Subscribe
- Permalink
@hockeypuck wrote:test speed are 230 to 250
directly connected?
And you've removed all splitters, amplifiers, attenuators?
- Mark as New
- Bookmark
- Subscribe
- Permalink
no, spilter in place for tv.. So I need to rebot without the splitter then reinstall? I want tv 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
@hockeypuck wrote:I have a netgear router after the modem. AC1200. I tested speeds through that.. Its rated for 600 download. I have tested both diret to modem and through the router. Speed is the least of my issues.. I want phone. My xfinity account has a phone number listed and active. Does it have something to do with the starting frequency being "0"
I don't have the cm1150v or any other voice devices so I'm not sure what there are for settings on the cm1150v to activate change settings for the voice aspect. Potentially the comcast rep provisioned it wrong because the reset of your power looks fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think I get what your selling.. need to get a new splitter for speed. But what about the phone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You're just removing the splitter for testing. If it fixes the issue, potentially the splitter could be causing the problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
which router was it? ac1200 is a speed.
And you were directly connected for speedtest?
What site did you use?
not sure what's changeable in the cm1150v for phone settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
model R6230. I just took out the splitter and attached the modem.. rebotted. still no phone. Download speed still 230.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would see if comcast can reprovision it for your service. It wouldn't be the first time the wrong provisioning was done.
If it doesn't help then its either the modem (a possiblity) or the line.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should i do a factory rebot on the modem and then do a new "enlist" with xfinity?
- Mark as New
- Bookmark
- Subscribe
- Permalink
shouldn't need a reboot. just call xfinity and have them reprovision it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just to update everyone.. spent too much time on the phone with xfinity. It was wiered that they could not even ping my router saying it was offline even though I have internet. Tech is coming out tomorrow. I wonder if my splitter it not the correct type. It was installed by comcast 10 years ago. Its a 2 way splitter, 5-1000mhz. -3.5 db out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you remove the splitter?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
