Orbi WiFi 7 RBE973
Reply
cm500 modem connects to ethernet on computer but cannot connect through router
chellesmeow
Hi, I just bought a CM500 modem to replace an outdated surfboard. I can connect if I use the ethernet port on my computer but when i try to connect to my router (and then connect the router to the ethernet port on my computer) I have no internet connection and the orange light blinks on the modem for the ethernet. Please help, I'm not overly computer savvy and this seems like I need a fix thats probably super easy. My router is a linksys E2500 and I have comcast. THANKS!
Model: CM500|16x4 DOCSIS 3.0 Cable Modem
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: cm500 modem connects to ethernet on computer but cannot connect through router
Hello chellesmeow
Have you tried to factory reset the router since you swapped out modems?
DarrenM
Message 2 of 4
chellesmeow
No, I don't know how to do that? I unplugged it and plugged it back in as the modems manual told me to.
Message 3 of 4
DarrenM
Hello chellesmeow
You may want to look up how to factory reset your linksys device.
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3014 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
