Orbi WiFi 7 RBE973
Reply
connecting a switch
brendaknoll
Follower
connecting a switch
Since this onlyhas one port, do I connect a switch to the modem? or do I let the modem find the wireless router wirelessly, and then conect the switch to the rouoter?
Message 1 of 2
Guru
Re: connecting a switch
What device are you talking about? you didn't put any models or anything for us to help with. so all we can give you is generals.
If its a modem only, it needs to go:
modem------->router------->switch
if its a modem/router combo device, then you can put a switch directly connected.
you can go to netgear.com/support/  and type in your  model. it'll take you to install guides, manuals, etc.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 294 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
