Orbi WiFi 7 RBE973
Reply
echo dot plugs and lights
tweeetycrazee
Follower
I restarted my modem and now I can no longer connect to the echo plugs and lights.  It still connects to the echo dot itself.  Thinking on this.. I can no longer connect to my printer wirelessly.  Please help?  Thank you in advance.
Message 1 of 3
Guru
Re: echo dot plugs and lights
You gave us nothing to go off.
What NG product are you referring too?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Message 2 of 3
Kitsap
Master
It would also be helpful to know what brand and model number of smart plug you are using.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 528 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
