× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
Reply
factory reset after power failure CAX80 RAX50
brettdotcom14
every time i have a power failure my cax80 loses my cable company info as well as my admin login security question and any other settings. same goes for my rax50 which i only have setup as an access point for the cax80 but i still have to reconfigure it. i backed up both to restore quicker but i was hoping there was a permanet solution. both firmwares are up to date. thanks
Message 1 of 12
Guru
Re: factory reset after power failure CAX80 RAX50
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
You may want post in the RAX forum for the RAX router you have:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Thank you.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 12
Guru
Who is your ISP?
Message 3 of 12
brettdotcom14
Both came with the latest firmware installed.
ISP is optimum
On the router I did do one factory reset because I forgot the password. Then reset everything and had a power failure and everything reset to square one
I don’t believe I ever did a factory reset on the cax80
Do you need the firmware numbers? I just know when I search for an update they say they’re the latest
Message 4 of 12
Guru
Please give FW numbers...
Can you try the CAX in modem mode and the RAX in router mode?
FYI, I also noticed this on my CAX80 the other day. I just did a reboot of the modem from it's web page and connected Orbi router lost internet access. I had to reset and setup the CAX80 from scratch.
Message 5 of 12
brettdotcom14
The cax80 is V2.1.3.5
The rax50 is V1.0.4.100
I can try setting it up that way. I wanted the rax50 to the an access point to extend my Wi-Fi
Message 6 of 12
Guru
Any updates on this?
Message 7 of 12
brettdotcom14
Unfortunately No still happening to this day anytime I lose power. I’m probably going to have to contact Netgear. Not that I lose power that often but it’s a bit annoying having to do to both of them every time.
Message 8 of 12
Guru
Have you tried newer FW yet?
https://community.netgear.com/t5/Cable-Modems-Routers/New-CAX80-Firmware-Version-2-1-3-7-Released/td...
If you have, I recommend downloading this to a wired PC first, Use MS Edge or Firefox to load the FW. After the CAX 80 is back online, press the reset button for 10 seconds or I prefer the ERASE button under Advanced Tab/Advanced Settings/Backup. Set the CAX up from scratch, then see if it still happens.
Message 9 of 12
brettdotcom14
I will give that a try. I know I had the app check for new firmwares but they said they were up to date. Appreciate the help and info
Message 10 of 12
Guru
NG may not put new FW updates on there auto update services so the modem or NH app may not catch anything. I try to post new stuff here in the forums as I see it come out or gets posted from NG.
Message 11 of 12
Guru
FYI:
https://community.netgear.com/t5/Cable-Modems-Routers/New-CAX80-Firmware-Version-2-1-5-2-Released/m-...
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 834 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
