Orbi WiFi 7 RBE973
Reply
intermitent cm1200 connection
jazo97
Follower
Hi, I have a CM1200 modem with spectrum, My service is 400mbps/25mbps I normally get the full Download and barely get 17mbps down, yesterday I started to have intermittent service, the modem goes off line and has to reconnect, I called for service and the man on the phone is blaming the modem. The logs on the modem are as follows.
I just factory reset the modem per the Spectrum tech on the phone.
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel759000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnabledBPI+
IP Provisioning ModeIPv6 Onlyipv6Only(1)
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM25631759000000 Hz5.6 dBmV40.1 dB20
2LockedQAM2561543000000 Hz7.6 dBmV41.4 dB00
3LockedQAM2562555000000 Hz7.6 dBmV41.5 dB00
4LockedQAM2563561000000 Hz7.3 dBmV41.4 dB10
5LockedQAM2564567000000 Hz7.3 dBmV41.5 dB10
6LockedQAM2565573000000 Hz7.6 dBmV41.6 dB10
7LockedQAM2566579000000 Hz7.4 dBmV41.5 dB00
8LockedQAM2567585000000 Hz7.4 dBmV41.5 dB00
9LockedQAM2568591000000 Hz7.4 dBmV41.6 dB00
10LockedQAM2569597000000 Hz7.7 dBmV41.7 dB00
11LockedQAM25610603000000 Hz8 dBmV41.7 dB00
12LockedQAM25611609000000 Hz7.9 dBmV41.7 dB20
13LockedQAM25612615000000 Hz7.7 dBmV41.2 dB00
14LockedQAM25613621000000 Hz7.9 dBmV41.5 dB20
15LockedQAM25614627000000 Hz7.8 dBmV41.5 dB10
16LockedQAM25615633000000 Hz7.9 dBmV41.6 dB10
17LockedQAM25616639000000 Hz8 dBmV41.6 dB00
18LockedQAM25617645000000 Hz7.7 dBmV41.3 dB00
19LockedQAM25618651000000 Hz7.5 dBmV40.9 dB20
20LockedQAM25619657000000 Hz7.4 dBmV40.9 dB20
21LockedQAM25620663000000 Hz7.7 dBmV41.2 dB10
22LockedQAM25621669000000 Hz7.5 dBmV41.3 dB10
23LockedQAM25622675000000 Hz7.3 dBmV40.7 dB30
24LockedQAM25623681000000 Hz7.3 dBmV41.2 dB00
25LockedQAM25624687000000 Hz7.4 dBmV41.1 dB20
26LockedQAM25625693000000 Hz7 dBmV41 dB20
27LockedQAM25626699000000 Hz7.1 dBmV40.9 dB20
28LockedQAM25627705000000 Hz7 dBmV40.7 dB10
29LockedQAM25628741000000 Hz5.3 dBmV40.3 dB20
30LockedQAM25629747000000 Hz5.6 dBmV40.4 dB00
31LockedQAM25630753000000 Hz5.7 dBmV40.2 dB20
32LockedQAM25632765000000 Hz5.3 dBmV39.8 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA25120 Ksym/sec24200000 Hz38 dBmV
2LockedATDMA35120 Ksym/sec30600000 Hz38.5 dBmV
3LockedATDMA45120 Ksym/sec37000000 Hz39.8 dBmV
4Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
5Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
6Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
7Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
8Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
Downstream OFDM Channels
ChannelLock
Status
Modulation /
Profile ID
Channel
ID
FrequencyPowerSNR /
MER
Active Subcarrier
Number Range
Unerrored
Codewords
Correctable
Codewords
Uncorrectable
Codewords
1Locked0 ,1 ,233285000000 Hz9.5 dBmV41.0 dB148 ~ 394743136542399002180
2Not Locked000 Hz0 dBmV0.0 dB0 ~ 4095000
Upstream OFDMA Channels
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPower
1Locked3 ,4 ,11 ,12 ,1395850000 Hz35.5 dBmV
Extended Upstream Transmit Power
Enable Extended Upstream Transmit Power
Current System Time:Fri May 27 16:14:24 2022
System Up Time:00:18:03
TimePriorityDescription
Fri May 27 15:59:25 2022Notice (6)CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=;CMTS-MAC=00;CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:59:24 2022Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=0;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:59:18 2022Warning (5)REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=0;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:59:18 2022Notice (6)US profile assignment change. US Chan ID: 8; Previous Profile: 13; New Profile: 11 13.;CM-MAC=00;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:59:14 2022Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=0;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:59:13 2022Notice (6)TLV-11 - unrecognized OID;CM-MAC=0;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:59:12 2022Error (4)Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=:00;CMTS-MAC=00:;CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:59:12 2022Error (4)Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=000;CMTS-MAC=00:;CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:59:04 2022Notice (6)Overriding MDD IP initialization parameters; IP provisioning mode = IPv6
Fri May 27 15:58:49 2022Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=0:00;CMTS-MAC=0b;CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:58:07 2022Critical (3)No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=0;CMTS-MAC=00CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:57:57 2022Critical (3)SYNC Timing Synchronization failure - Failed to receive MAC SYNC frame within time-out period;CM-MAC=00;CMTS-MAC=00:;CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:57:57 2022Warning (5)REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=000;CMTS-MAC=00;CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:57:55 2022Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=0;CMTS-MAC=00:;CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:57:54 2022Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=000;CMTS-MAC=00:;CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:57:47 2022Notice (6)TLV-11 - unrecognized OID;CM-MAC=08:36:c9:42:94:00;CMTS-MAC=0;CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:57:47 2022Error (4)Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=0;CMTS-MAC=00;CM-QOS=1.1;CM-VER=3.1;
Fri May 27 15:57:47 2022Error (4)Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=0;CMTS-MAC=00;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedNotice (6)Overriding MDD IP initialization parameters; IP provisioning mode = IPv6
Time Not EstablishedCritical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
I dont think I have a bad modem, however, I am looking to maybe rent theirs for a month or two just to make sure.
Anyone has any suggestions??
Message 1 of 2
olympos1625
NETGEAR Employee Retired
Re: intermitent cm1200 connection
Hi @jazo97,
Good day!
Welcome to NETGEAR Community!
Thank you for reaching out. We are sorry for the inconvenience this has caused you. DId they re-provision the modem? Have you tried contacting our support team about this matter? Is there any changes on your network?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 490 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
