× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
Reply
nighthawk C7100V ping delays
junaid27
Follower
Using netgear C7100V with Xfinity cable connection. I am facing ping delay time (up-to 30ms) on wired cable directly connected to my laptop. Overall performance via cable modem/router is not stable. No ping drops to internet or on lan but some ping time gets high in between. What can be the reason. Pls help. Thanks in advance.
Message 1 of 2
Guru
Re: nighthawk C7100V ping delays
How are you testing these ping times?
I find a lot of people say they have ping issues when hardwired and then when you figure out where the issue is, its not in the computer---->router/modem connection. Its after that going modem---->isp----level3/other backbone supplier.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 214 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
