Orbi WiFi 7 RBE973
Reply
port forwarding with an internet phone
Gamedroid
Tutor
ive been trying to port forward to setup some game servers but ran into a problem when i might have three seprate routers.
using a check multiple routers tool i downloaded i discovered i have two regular routers, a netgear(192.168.1.3) and an xfinity(10.0.0.1). but checking on the connected devices for the xfinity router showed one device being my internet based phone(10.0.0.2) which has its own port forwarding page.
it anyone could lend a hand on this it would be much appreceited as i dont even know where to begin with this.
Message 1 of 3
Gamedroid
Tutor
Re: port forwarding with an internet phone
let me add some screen caps to make this a bit more clear
detect router
this is the two supposed routers on my network
the being a netgear router and the second being an xfinity/comcast one
xfin
the xfinity router also shows another device connected, connecting to it shows this
oma
this is also somehow the domain server for the netgear router
internetomla
i should also point out the xfinity routers port forward page has the servers ip mostly grayed out
ip
Message 2 of 3
DarrenM
Sr. NETGEAR Moderator
Hello Gamedroid
You should only have 1 router handling the DHCP so you will either need to bridge the modem or turn the other routers into access points so then you will be able to port forward your devices.
DarrenM
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2127 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
