- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
A6100
- Mark as New
- Bookmark
- Subscribe
- Permalink
A6100
I am trying to use the A6100 on my tv and I can’t get it to pick up my NETGEAR router. I have attempted to use the wps without success. Any suggestions would be helpful
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: A6100
> I am trying to use the A6100 on my tv [...]
Not a very detailed description of your "my tv".
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the Product Data Sheet. Read. Look for "System
Requirements". Does your "my tv" run Windows? I doubt it.
I assume that you have some kind of TV or other which has an Ethernet
port, and you want to connect it wirelessly to your (unspecified) "my
NETGEAR router". You might check with the maker of your "my tv", and
see if it supports any kind of USB wireless-network adapter. If not,
then you might shop around for a wireless bridge, which can connect to
the Ethernet port on your "my tv", and handle the wireless-networking
function.
Or run an Ethernet cable between your (unspecified) "my NETGEAR
router" and your "my tv". Or get a pair of Powerline gizmos, and use
them and your house power wiring to emulate an Ethernet cable.
