- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1000
- Mark as New
- Bookmark
- Subscribe
- Permalink
AC1000
I purchased the AC1000 and was told it had an on/off switch for wifi, i have a spectrum wireless modom which only allow me to connect one device and was told to purchase a router to add more devices. I am looking for a way to have wifi off and use the hardwired ethernet connect with 3 devices. Due to my husbands illness i need wifi off most of the time. Since i have an iphone and ipad i do want to turn wifi on when he is not present to update my apple devices.. When the wifi button is pushed off on the AC1000 the other harwired devices aren't connected to the internet. So is there another way i can use 3 devices hardwired to the internet without wifi turned on while the others are in use? Does this call for use of a switch? Need to return this Netgear AC1000 shortly if it is not the right option for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1000
> I purchased the AC1000 [...]
Is that a model R6080? Look at the product label.
> [...] and was told it had an on/off switch for wifi,
Were you told where it is? Visit http://netgear.com/support , put in
your (actual) model number, and look for Documentation. Get the User
Manual. Read. When I do that for an R6080, I don't see such a button.
The only prominent button I see is the "Power On/Off button".
> [...] When the wifi button is pushed off on the AC1000 the other
> harwired devices aren't connected to the internet. [...]
Actuating the "Power On/Off button" could account for that. What
happens to all the LED indicators when you push that "the wifi button"?
> [...] i have a spectrum wireless modom which only allow me to connect
> one device [...]
Does it have a maker and model number? If it's really a _wireless_
modem, then it's probably a wireless modem+router, and you'd also want
to ensure that its wireless radio is also off. (If, that is, you really
believe that a wireless router can affect anyone's health).
If this (unspecified) "a spectrum wireless modom" has been configured
as a modem-only ("bridge mode"), then its radio may already be disabled.
That would make some sense, if you're using it with another router
(like, say, an R6080).
> [...] is there another way i can use 3 devices hardwired to the
> internet without wifi turned on while the others are in use? [...]
For a start, don't power down the router? You should be able to
control the radio(s) from a computer/device with a web browser which is
connected to the router. Look in the User Manual for "Enable or Disable
the WiFi Radios".
Some other Netgear router models do have a "WiFi On/Off button". For
example, the R7000. (Repeat the procedure above to see the R7000 User
Manual.)
> [...] Does this call for use of a switch? [...]
Not an Ethernet network switch. To use multiple devices you need
some kind of router.
