- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Are All Nighthawk AC1900 R7000 Routers Cable Modems?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should all AC1900 R7000 routers work as Spectrum cable modems as well?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All R series routers are just routers only. There is no modem built in. If you need a router with a built in modem, then any C series modem will have both a cable modem and router all in one unit for Cable ISP services. If your on DSL, then any D series modem will have both a DSL modem and router all in one unit for DSL ISP services.
Please refer to the ISP for what is officially supported on there network before you buy.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Are All Nighthawk AC1900 R7000 Routers Cable Modems?
I’m trying to find a cable modem with WiFi for a weekend house similar to the C6300-BD I use in my home, fit your website doesn’t make it easy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try this link to NGs product page for cable modems with built in routers:
https://www.netgear.com/home/products/networking/cable-modem-routers/
Good Luck.
@cyberbiker wrote:
Thanks! Just what I needed. I wish such clarity was on the website as we were searching for the right piece of equipment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do I tell whether The C7000 being offered is Version 1 or 2?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You would need to ask someone where your thinking about getting the C7000 to look at the box they have in stock to see weather it says v1 or v2 on the sticker on the box. I don't know for sure what the actual differences are. You might compare the spec sheets for each version on NGs support site.
