- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Arris sb8200 not running 3.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hopefully my post is in the right spot and makes sense. I have Cox Gigablast, with an Arris SB8200. Supposedly running DOCSIS 3.1, but my up and down lights are and have been green for some time. Cox insists that 3.1 is running just fine. 2 different techs have been out, first one said the signal was too low, so he took off the splitter. He wanted to check the line off the pole to the house, as well as the junction up on the pole/line but it was too windy for his comfort level. A week later, different tech comes out, tests the line, and says the signal is too high, and puts a splitter back on. Contacted Arris support, they suggested a factory reset, which I did. Still all green lights. Here are the event logs and status reports
Channel ID | Lock Status | Modulation | Frequency | Power | SNR/MER | Corrected | Uncorrectables |
13 | Locked | QAM256 | 855000000 Hz | 8.4 dBmV | 43.7 dB | 205 | 961 |
1 | Locked | QAM256 | 783000000 Hz | 8.6 dBmV | 44.1 dB | 237 | 1115 |
2 | Locked | QAM256 | 789000000 Hz | 8.4 dBmV | 44.0 dB | 103 | 424 |
3 | Locked | QAM256 | 795000000 Hz | 8.7 dBmV | 43.9 dB | 98 | 252 |
4 | Locked | QAM256 | 801000000 Hz | 8.7 dBmV | 43.9 dB | 91 | 252 |
5 | Locked | QAM256 | 807000000 Hz | 8.5 dBmV | 43.9 dB | 91 | 258 |
6 | Locked | QAM256 | 813000000 Hz | 8.8 dBmV | 43.9 dB | 115 | 231 |
7 | Locked | QAM256 | 819000000 Hz | 8.5 dBmV | 43.8 dB | 101 | 291 |
8 | Locked | QAM256 | 825000000 Hz | 8.4 dBmV | 43.7 dB | 110 | 297 |
9 | Locked | QAM256 | 831000000 Hz | 8.7 dBmV | 43.6 dB | 210 | 451 |
10 | Locked | QAM256 | 837000000 Hz | 8.5 dBmV | 43.8 dB | 242 | 687 |
11 | Locked | QAM256 | 843000000 Hz | 8.6 dBmV | 43.9 dB | 297 | 1070 |
12 | Locked | QAM256 | 849000000 Hz | 8.6 dBmV | 44.0 dB | 398 | 1700 |
14 | Locked | QAM256 | 861000000 Hz | 8.4 dBmV | 43.9 dB | 518 | 2145 |
15 | Locked | QAM256 | 867000000 Hz | 8.2 dBmV | 43.9 dB | 499 | 2583 |
16 | Locked | QAM256 | 873000000 Hz | 7.9 dBmV | 43.5 dB | 563 | 2672 |
17 | Locked | QAM256 | 879000000 Hz | 7.6 dBmV | 43.7 dB | 537 | 2567 |
18 | Locked | QAM256 | 885000000 Hz | 7.4 dBmV | 43.6 dB | 364 | 1980 |
19 | Locked | QAM256 | 891000000 Hz | 7.4 dBmV | 43.6 dB | 326 | 1475 |
20 | Locked | QAM256 | 897000000 Hz | 7.3 dBmV | 43.7 dB | 153 | 885 |
21 | Locked | QAM256 | 903000000 Hz | 7.1 dBmV | 43.5 dB | 86 | 428 |
22 | Locked | QAM256 | 909000000 Hz | 7.3 dBmV | 43.6 dB | 119 | 181 |
23 | Locked | QAM256 | 915000000 Hz | 7.1 dBmV | 43.5 dB | 110 | 184 |
24 | Locked | QAM256 | 921000000 Hz | 6.9 dBmV | 43.5 dB | 120 | 180 |
25 | Locked | QAM256 | 927000000 Hz | 7.4 dBmV | 43.7 dB | 85 | 231 |
26 | Locked | QAM256 | 933000000 Hz | 7.2 dBmV | 43.5 dB | 79 | 273 |
27 | Locked | QAM256 | 939000000 Hz | 6.9 dBmV | 43.0 dB | 76 | 273 |
28 | Locked | QAM256 | 945000000 Hz | 7.0 dBmV | 43.5 dB | 76 | 295 |
29 | Locked | QAM256 | 951000000 Hz | 6.7 dBmV | 43.4 dB | 110 | 372 |
30 | Locked | QAM256 | 957000000 Hz | 6.8 dBmV | 43.4 dB | 190 | 488 |
31 | Locked | QAM256 | 963000000 Hz | 6.4 dBmV | 43.3 dB | 241 | 944 |
32 | Locked | QAM256 | 969000000 Hz | 6.0 dBmV | 43.4 dB | 368 | 1329 |
159 | Locked | Other | 300000000 Hz | -44.3 dBmV | 0.0 dB | 0 | 0 |
